2006 Range Rover L322 4.4
Hi all,
The 2006 4.4L MAF sensor is the Denso # 197400-3021 or otherwise known as the DMA-0113
Denso has many other 197400-XXXX numbers that are the same DMA-0113
When I search the net I found various Denso MAFs and in a great variety of prices.
Notably the 197400-2030 fitted in Toyotas, less than half the price, claiming that will fit the RR 2006 4.4L.
But on the Denso website this is a DMA-0108 MAF sensor, and the compatibility chart does not include neither Land Rover neither Jaguar.
It has been mentioned on this forum but has anyone tried it ?
Thanks,
Aristides
I have, it works fine. I originally put it in when I was battling the Lean Bank 1 and 2 codes a couple of years ago. I took it out recently when I had a coil failure when I was trouble shooting the issue and put the original back in. No noticeable different in the way it runs with either MAF.
Font Gas Auto part Grass Art
I have, it works fine. I originally put it in when I was battling the Lean Bank 1 and 2 codes a couple of years ago. I took it out recently when I had a coil failure when I was trouble shooting the issue and put the original back in. No noticeable different in the way it runs with either MAF. View attachment 296334
The only reliable part in a RR. Toyota
