1 - 20 of 119 Posts
JACK'S GRANDAD
Looks like the wife's 2003 Rover will be getting timing chains, guides and tensioners done, as well as the Vanos seals from Beisin. We looked at trading it against a really clean '08 Supercharged, but the numbers weren't making sense to me.
So if we're keeping it, I'll get rid of the noise it makes all the time pretty much. Think it's trying to impersonate my daily driver....
I'll be doing some reading, but if anyone wants to chime in with part numbers and suppliers, I'd appreciate it. I've seen a few threads that threatened to post part numbers etc, but never did. I also shot Will Tillery an email asking for a package deal, so I'll see what he says. BMW parts would be my first choice, as they lasted 185k miles so far.
Martin
Buy parts from ECStuning and eEuroParts, IWIS is great for chains, but nothing else. Stay away from VAICO and MTC for guides, they're the definition of cheap parts.. If you go to the BMW dealership for coolant, ask for a discount and they'll usually give you a few dollars off. Maybe that just because I know the BMW/LR dealership.. Goodluck!
Oh, you will need a 3/4 27mm for the crank bolt.. I snapped a solid 1/2 drive breaker bar, make that two :lol:
LLT. Thats some rig. Is that an Arnott system on the tag axle. I have never seen anything like your rig on our local highways.
I can't comment on you rig, but it sure looks clean!
Don't forget the non return valves, it'll also halt some of the knocking..
JACK'S GRANDAD
Arnott make nothing for commercial use.
The pusher axle (A tag axle goes behind the drives), is a Hendrickson 20,000lb capacity item.
You wont see them up there like mine because they dont recognize a lift axle for some retarded reason, and it's too long for the idiotic laws up there. Max wheelbase up there just got increased to 285" IIRC. Mine is 302".
Martin
JACK'S GRANDAD
I can get this, for just over a grand delivered.
http://www.roverparts.com/Parts/TCKL322
Thoughts?
And I'll order a 27mm 3/4" drive socket I guess......seeing as my 1/2" drive stuff wont handle the bolt! I have heard it called the "Jesus bolt" before.
Martin
Thoughts?
Martin
If your 1/2 stuff has a warranty I'd try it, you'll need a 6 ft breaker bar (okay well that would be a little extreme, I meant cheater bar..) and probably two people :lol:
I think that kit is overpriced, I spent around $550 on all of my project, VANOS and guides/chains. Note that the BMW e53 X5 has the same kits, and are usually more reasonable. Make sure it's the M62 X5 either 4.4/4.6/4.8 and not the N62. I ordered a couple wrong parts because of that silly mistake.
The kit I based off was this: https://www.ecstuning.com/b-assembled-by-ecs-parts/timing-chain-kit/11311435026kt6/ that weird funnel shaped thing you won't need either..
I deleted some of the parts that I wouldn't need and I replaced some of the overpriced OE BMW parts with trusted suppliers like Bosch and Febi. I wish I could just list down the parts I bought but unfortunately didn't write anything down.
JACK'S GRANDAD
I dont mind going genuine parts, if it last another 185k miles.
On top of the timing stuff would be the Baisin Vanos stuff, cam holding tools, and a water pump.
New crank bolt from my reading too, seeing as its a stupid stretch bolt (Why oh why??)
So you're saying you got all the timing stuff, gaskets, seals, and the Vanos crap for @$550????
My 27mm is an impact socket. It's got warranty from HF, but maybe that is my warning, HF!!! ROFL
Of course, if you fancy a trip to Mo, the wife makes really good food and you can drive the Lsx powered P38 in your down time......:lol:
Martin
I bought all genuine BMW parts (getBMWparts.com) and it cost me around $1,300 plus another $300 in tools.
You'll need a 3/4" drive breaker bar and socket to remove the crankshaft bolt.
I also spent $150 to have the camshaft covers media blasted and powder coated.
Here's a parts list I have:
Timing Chain - Iwis (OEM) 11311741746
Center Crankshaft Bolt - Genuine BMW 11231736585
Cylinder Head Oil Check Valve (E38 E39 E52 E53) - Genuine BMW 11121706921 (x2)
Timing Chain Guide Upper - Genuine BMW 11311435028 (x4)
Oil Separator (540 740) - Genuine BMW 11151705272
Valve Cover Seal Washer - Elring 11121437395 (x16)
Valve Cover Seal Washer - Reinz 11121721879 (x6)
Camshaft Solenoid Gasket - Reinz 11141435023 (x2)
Valve Cover Gasket Set Left - Reinz 11120034105
Valve Cover Gasket Set Right - Reinz 11120034104
Oil Dipstick O-Ring - Reinz 11431707164
Distribution Housing Gasket Left (Cylinders 5-8 ) - Reinz 11361705579
Distribution Housing Gasket Right (Cylinders 1-4) - Reinz 11361705578
Water Pump Gasket - Genuine BMW 11511731372
Alternator Gasket/O-Ring - Bosch F00M258503
Timing Chain Guide Left Lower - Genuine BMW 11311745406
Timing Chain Guide Rail - Genuine BMW 11311741777
Timing Chain Guide Rail - Genuine BMW 11311741236
Timing Cover Gasket Set Lower - Reinz 11141436978
Crankshaft Seal Front - Elring 11141275466
Timing Cover Seal Strip (Cylinders 5-8 ) - Reinz 11141741128
Timing Cover Seal Strip (Cylinders 1-4) - Reinz 11141741127
Coolant Pipe O-Ring - Reinz 11531710048
Coolant Pipe O-Ring - Reinz 11531710055
Beisan Systems M62tu Vanos Kit
Beisan Systems Pick Tool Set (optional but extremely useful)
Timing Chain Tensioner Lower - INA 11317531813
Oil Pan Gasket - Reinz 11131436324 (540i/740i) | Elring 11137500261 (X5)
Oil Level Sensor O-Ring - Victor Reinz 12611744292
Seal Ring - Genuine BMW 11141736758
Oil Filter Kit - Hengst 11427510717
Motor Oil - 8+ quarts (I used Mobil 1 0W40)
Coolant - 2+ gallons (I used a 60-40 mixture of BMW coolant and distilled water)
I made this list for all M62tu engines, so just use the X5 parts where applicable. The M62tu in the X5 is identical to the M62tu in the Range Rover. I did a chain guide job in my formerly-owned 2004 Range Rover and then in my 2003 X5 4.6. The procedure was more or less identical, aside from some silly quirks like the dipstick tube location (it was on the side in the Range Rover and in the front on the X5).
I highly recommend the German Auto Solutions tools: https://www.germanautosolutions.com/bmw_solutions/tools/cam_tools/m62_m62tu_cam_tools/product_m62_pro_cam_tools.php They're much easier to use than the other tools.
JACK'S GRANDAD
Discussion Starter #12
So it sounds like Will Tillery's price for genuine parts is inline then?
I can get a 3/4" drive socket, no big deal as I have a 3/4" SAE set already, so have a breaker bar etc.
Cam covers got powder coated etc when I got the rig, and redid all the gaskets etc up there.
Martin
JACK'S GRANDAD
Discussion Starter #13
DANNY, thank you!!!!
I will get online and do some checking tonight, see what I come up with mate.
I've seen the cam locking tools on Ebay, but will follow your lead and get the one you mentioned if you have tried different ones.
I'm trying to decide what to do first...... I have a pair of locking FJ80 axles to go under either a P38 I have sitting here, or the DII.
EAS on my LSx powered P38 is going nuts, until I just pulled the relay!
Youngest kids 924 wants attention, but he's only 13 so....
Then the wife's MkIII timing chains and vanos.
Only thing that is good is the middle kids (14yrs old) GMC Envoy now I sorted the cam actuator etc. Go figure huh?
And I picked up a 3/4" drive 27mm socket when I went to town, so getting there....rofl
Martin
JACK'S GRANDAD
Discussion Starter #14
Danny,
Guessing the "Master" kit over the "Professional" tool kit, due to being able to lock both banks at once? I would imagine doing each bank one at a time would be a major PIA....
Martin
Danny,
Martin
Yeah you'll want the Master kit. Doing one bank at a time just increases the chances of something going wrong. It's only $250 for a very high quality, made in USA kit, so it's well worth the price.
I previously had the older style timing tools and while they worked fine, they weren't as precise and I often ended up needing to adjust the timing afterwards.
JACK'S GRANDAD
Discussion Starter #16
Master kit ordered from GAS.
Beisin stuff ordered, seal kit, extra teflon seal, press and picks.
Looking at this, all good brands and everything I need? Not all BMW/LR like the AB kit, but just as good?
Will replace the water pump while its off, unknown when it was done last.... Genuine or ??
Same as the E53 X5 water pump?
Martin
That list will be awesome for when I start the guides on both of my 04s, and while I'm here, how's the X5 doing, Danny?
I'll agree on the timing set from GAS, the ones that I own, the standard set, are horrendous compared to GAS tools.
I'd go genuine for the water pump, but if you find an aftermarket and do some searching on the company it's good. I use a GRAF pump with the metal impeller and it's been great for the past 20k miles, no play whatsoever. Then again, 180k vs 20k..
JACK'S GRANDAD
Discussion Starter #19
Genuine BMW X5 unit, or LR unit?
They "look" the same, but.......
What about the whole "kit" from ECS?
As you may have gathered, I dont have the time to order a piece here and a piece there.No telling when I head back out again, and have @4 other rigs to keep on top of, besides the Western Star!
Martin
Martin
So? Isn't that normal P38 operation? :lol:
I don't think my EAS ever worked, but I guess I was a high schooler with a mother who only let the dealership do repairs :roll:
They're the same, at least I hope.. I've been running an e53 pump so you can get either genuine LR or BMW if you want genuine parts. I think it'd be beneficial to take half an hour and create a shopping list based on Danny's parts on whatever website you'd like. Whether it be ECS, eEuro, FCPEuro, or AutohausAZ.
1 - 20 of 119 Posts
