What is the correct torque spec for the wheel lug nuts on a '06 Range Rover Sport Supercharged?
Thanks,
TJ
A very similar question occured to me as I was jumping up and down on the lug wrench on the side of the road a while back..."I wonder what torque my dealer's impact wrench drives the lugnuts to?" My carefully calibrated right leg tells me it might be more than 140Nm +/- 10.
Discussion Starter · #6 ·
More likely the lugs were seized a bit. The differing material between the wheel and lug, and lug and stud can cause them to seize up over time. I run anti-seize on the threads of the studs and contact surface of the lug (very, very little is needed) on my race car. I wonder if there would be any downside to running anti-seize on my RR?
-TJ
These were waaay overtightened. The tech musta had the ol' impact wrench at the dealer set for 150Nm+/-10 `)
-TJ
There is a downside to running anti-seize on the lug: the 103ft-lbs is a dry torque rating. Lubricating the threads makes it extremely easy to overtorque the lugs, and possibly cause a wheel failure. I think it's possible to roughly figure out the lubed torque value - but by feel Id think it's something closer to 80-ft-lbs.
