Ladies and gentlemen. to be more clear my truck is a 07. My 05 had the conical style and this doesn't. As a few of you stated some trucks have the conical style and the traditional syle. It is not uncommon for people to convert in order to expand wheel choices not sure.
either way one i get the new tires ill figure it out. good info though which clarify somethings
To be more clear? Dont you mean "what I should have said in my first post"?
And you "know for sure" its been converted to "lugs and lug nuts"?
May I ask....WTF are you talking about? ALL L322's had lugs (studs) and nuts. Are you really saying some idiot removed all the studs, put different ones in there, then installed some junk after market rims with a different style lug nut? The lug nut I have no problem with, that was probably more ignorance from an AutoZone acne riddled teenager than anything else, but the studs? Nope.
Why would anyone swap studs out? To try to utilize those "Dubs" sitting in the corner that were actually made for a 1979 Caprice?
This is why I dont buy rigs that have been attacked by African tree monkeys with a brain disorder.
By all means, pull the caliper, axle shafts, differential, and so on, to show us these magical "lugs" though.... Or just get a set of OEM lug nuts and install some Rover wheels to your Rover.
Martin
