1 - 9 of 9 Posts
Is there a difference in Lower rear tailgates for the hard dash and soft dash models? I've been offered a hard dash version but have a feeling there is something about the mounting hinges?
both the same if from late vehicles, early hard dash vehicles had a different latching mechanism - think this was pre 1988 models which had the latch mounted externally.
i.e. if the latch is internal it should fit.
I believe (but I could be wrong) that there was a difference between the high and low filler cap tailgates too. When I had a GRP one fabricated, they had two patterns, one for the high level filler cap model and one for the low level one. Don't know what the difference would be. They did not have a pattern for ones with an external latch at all
The plot thickens!
I heard the hinges (and subsequently the mounting brackets) are age specific but its unconfirmed.
Roo said:
The plot thickens!
I fitted a good used lower lid on mine, the 'new' one's hinges were in a slightly different place and had to modify the holes to get it to fit :think:
adam1977 said:
Roo said:
The plot thickens!
Strange. Thanks for the info. I'm collecting it this weekend so we'll soon see!
The brackets for the later models are different and there are no mounting rubbers on the late ones either. As a previous poster stated you will only pick up one of the holes on each side to bolt the tailgate to the hinges.
The tailgate will fit but you should bend the two brackets mounted on the bottom of the tailgate frame inwards or the tailgate will close against these brackets and take the paint off and bend the corners of the tailgate outwards. I did not notice this until I tried to close the tailgate and caused this damage.
1 - 9 of 9 Posts
