2008 Range Rover HSE 155k
haven't changed radiator, water pump...
did replace belts and the lower radiator hose to thermostat 3 months ago.... as ihad a leak.
So after a few months it appears that i have another coolant leak... this time it appears to be from the other lower radiator hose..
the check coolant light comes on after 30 minutes of highway driving at 30-50 mph.... ive topped it off a few times, but even with the reservoir not showing low, the check coolant light comes on.....
i brought car to my mechanic who took a look and thinks it is from the other lower radiator hose... he topped off the coolant and im going to bring it back... he said that there are no evidence of leaks from the top of the engine...
he removed the cover to the bottom front of the car and so i parked the vehicle in my driveway and placed a carboard on the bottom and very little coolant appears on the box,,, just a drop or two the size of a nickle… there is some coolant on the frame/hoses from below, which i need to take a better look,, or at least have the mechanic look again....
a few questions
1) i haven't changed the thermostat or water pump in this vehicle 2008 HSE with 155k miles.... should i just change these as part of preventive maintenance.. not sure if changing the other lower radiator hose implies lots of work that i might as well change these as well
2) since i continue to get intermittent check coolant level, even with reservoir tank not showing low, anything else to do?change? Coolant sensor?
i have the iland device, when i scan, i don't get any codes.... what should the coolant temp read? any specific things to check to help me diagnose any other coolant problem?
rover runs great, no issues..... as it appears to not be a gasket, valve issue, id like to fix this and change out any other parts in prevention, so i don't have to keep going back every few months for another hose/part that needs to be swapped out.
thanks again for your feedback and help... this site is really amazing...
