Went through most of my washer fluid last weekend and the light came on. I filled (to the point of overfilling) it and it's still on. Anyone know if pulling the fuse would re-set it. I'm under warranty but wouldn't mind avoiding a dealer trip. thx for any help.
· RIP Our Friend
First thing to check is the connector at the sensor. If washer fluid has been on it it may be corroded. My neighbour's wife is not very graceful when she tops off their washer fluid. They do a lot of travel over the mountain passes. He has had to clean that connector several times to get the light to go out.
How do you acess the sensor connector? Where is it located?
Curious if you sorted this one yourself? I have recently purchased a used 2017. I got the low level warning, so I added 1 gallon of fluid. The low level warning did not go away, so just wondering if I have to completely fill it to get the warning to go away? or, will I need to find and clean the sensor connector?
