Hey guys, the other day in my 03 l322, the transmission started acting up. I parked on the side of road for around 20 minutes, and when I jumped back in the Range Rover and took off in drive, it would start to move and shift up a couple gears, but then instead of continuing forward it would only rev up on the rpm ( around 3500-4000 ), and then grab the transmission gear and jerk the vehicle forward. I tried driving up a hill and it was only revving on the RPM, and wouldn't even go an inch up hill.
Fast forward to today ,I let the Range Rover sit for a couple days, and hopped in to start trouble shooting, and it started driving fine. No missing shifts, or no RPM rev in drive. I took it up a couple hills off a cold start, and it worked beautifully. The transmission shifted smooth, and I cruised up the hills. I drove for around roughly 10 minutes, and then as I was finishing my climb of a small hill, at the very top the RPM revved up for a split second and the transmission caught, and then everything went back to normal. I did a U-Turn, and coming down the hill the transmission and RPM did the exact same as coming up.
Could this be the cause of low transmission fluid?
Thank you all.
Thank you all.
