Decided to play around with my RR's low gears for the first time today, but when I went to put the low gears in, nothing happened. I have made sure that I was in neutral etc, but still the low gears would not enable. NO warning lights came on. Not sure what I should do
Thanks, but I don't think this is the case. There is a noise, as of it tries to enter low range, but never gets there. What could this be?
Discussion Starter · #6 ·
Thank you phil, for those excellent videos! I will try this out this weekend if possible and let you know of the results :)
Does this just sort of 'revive' the unused motor? As it had hardly been used.
Also if this is not the fix, what would solve this irritating problem?
