i wanted to write this so it hopefully helps someone else because it drove me CRAZY
i was getting a low coolant warning all the time.... so i replaced the sensor with an aftermarket one. still did the same thing.
so i figured had to be float in the bottle. so i ordered an aftermarket one of those, installed etc. it came with a sensor. still same warning.
being a mechanic by trade, brain tells me no way the new float is crap so i figured the two aftermarket sensors were crap. went to land rover
purchased a factory one AND THE SAME PROBLEM....
still figured no way its the new bottle, paper clip jumped the sensor and the LIGHT WENT AWAY--- THANK GOD
went to land rover and bought a new OEM coolant res with OEM sensor PROBLEM SOLVED.
the point of this is dont try to save the $45 dollars on the bottle-sensor setup Just buy the factory one.....
ok sorry rant over
2006 SC... the TSB is correct.. just never mentioned the aftermarket fact. just if anyone had my problem didnt want them to drive themselves crazy like it did
