1 - 9 of 9 Posts
Hi Guys,
I have looked at 3 P38's 2001 - 2002 in Cali, all of them had low coolant, about half inch under the cold level.
I walked away from the cars as i was concerned about where it had gone, should i be concerned?
Thanks,
Dan
Not particularly. They do tend to settle a bit below the line
Thanks, i did check the footwells, cooling pipes, looked around the engine and also checked the top hose for high pressure once warm, but i could not find any leaks.
More important to check mileage, any service history, who does the maintenance (owner or garage/dealer and which).
It's gonna be a combination of the above that impacts how good the car is. There's plenty of well maintained high-mileage, and lots of low mileage with problems car out there. Also depends on whether you can do any fixes yourself, or have deep pockets for what will come up.
I always do a 10-20 mile drive, and offer to pay for the fuel !!
I recently fixed a coolant leak on mine and it has settled at the same point you mentioned.
It never goes below this point but if I top it up again it will resettle there after a while.
I don't think there's anything to worry about.
Hi Guys,
Thanks,
Dan
The fact that all 3 had about the same level, says it all really. If there was a leak, the levels would surely differ and probably be a lot lower. I'd be more worried if the level was above the mark, as that is a clear indication it has recently (just) bee topped up, possibly to mask a problem.
JACK'S GRANDAD
A fingers width under the seam, is where they all settle to.
If you are after a car in SoCal, contact Scotty at www.becmdoctor.com.
He's in Victorville, and knows where the good ones are burried lol
Martin
Mine did that a couple of times after I replaced the radiator. Probably just a little air in the system. Last time I topped it off was 2 months ago and it's stayed right on the line.
Oh WOW, my problem has been fixed. I have been putting in about a cup of water every week, cannot find the leak. If I leave it for a month it still takes a cup of water :)
1 - 9 of 9 Posts
