Couple of questions......
Did the fob batteries die?
Did you replace them, noting the small contact on the cover was in place before tightening it?
Does the led on the fob illuminate?
If you have changed batteries, you may need to re sync the fob.
Possibly the low battery message was triggered, and Becm is now awaiting new info from the fob?
The fobs are becoming as scare as unicorn poop, so do try to fix what you have......
Annette, in Costa Rica has mentioned being able to get a fob that will work on NAS vehicles from a supply down South. Have not gotten confirmation yet.
I am also aware that Dr Scott (Retired) Becm Guru can make a fob from another P-38 work if he can read the Becm from the other truck. I am unclear as to what the exact procedure is, or if it requires putting your Becm on the bench as well?.....Have not gotten confirmation on that one either......
The only source I am sure of would be the dealer network, HOWEVER, you will need to buy a "Kit" which is over a grand, but has 2 fobs, and the door lock and ignition lock.
Spare individual fobs from N.A. dealers are off the menu.
