Right behind that little 1" square panel with the louvers on it, on the left side of the HVAC controller in the dash under the LH temperature control knob. #14 below
Stick your ear down by it and see if you can hear a whine from it. The fan is behind that grill, and is an integral part of the temperature control module.
Sometimes you can get a whistle if one of the 7 dampers in the dash doesn't fully open or close. Make sure you run the HVAC controller thru all the different modes (defrost, upper dash, floor, recirc, outside air etc) to exercise all the doors to see if the whistling noise comes or goes in one or more of those modes.
