Hello all, I have recently Baught a Range Rover and there is a horrible screeching noise coming from drivers wheel, the noise seems to go away and then come back from time to time, but every time I take it out the noise happens, There is also a clunky noise just like something clicking out of place around the same area of the screeching noise, please click link to listen to the video, that is the screeching noise when I go around a corner, it doesn’t happen around every corner I go around tho, but when it happens it’s very loud! Just wondered if anyone on here has had the same issue? Thanks people
https://share.icloud.com/photos/0fl7ztvIIW6jwu57YA7pscYIg#Partney,_Spilsby_&_Stickford
https://share.icloud.com/photos/0KdKcNkjXNiUovGo1ApMFAbBg#Partney,_Spilsby_&_Stickford
SUPER MODERATOR
Possible issues:
1. Worn out wheel bearing
2. Something stuck between the brake shield and the brake discs
3. Bent steering structure...wheel scraping?
4. Brake caliper stuck...brake dragging?
Jack it up, look for wheel wobble if you know how, or take it to a garage to have them review it.
check brake shield, is it band or lose.
Bradiswright, I am having the exact same issue. Just started today. Did you figure out what the issue was? I'm guessing that it is the front wheel bearing.
