Dropped off the car at the dealer for a 30K mile service. Picked it up, started driving it. There is a high-pitched squeaking noise coming from suspension (both sides) when driving over bumps, potholes, speed bumps and any road imperfections that cause the body to rock to side. It sounds like rubber squeaking. It is NOT clunking, NOT rubbing and NOT knocking. It's literally a rubber squeak. It only happens at low speeds (or maybe I just cant hear it at highway speeds). If I drive completely straight over a speed bump, the sound is NOT heard.
Here is a list of things they claim to have done:
J# 2 52LRZZ1010030 (M/A/S) 30K UNITS: TECH(S):5669
RESET SRI (SERVICE REMINDER INDICATOR)
RENEW ENGINE OIL
REPLACE ENGINE OIL FILTER
CHECK CONDITION AND SECURITY OF SEATS & SEAT BELTS
IF FAULT CODES ARE PRESENT USE IDS TO DETERMINE FAULTS
CHECK OPERATION OF ALL LIGHTS. WARNING INDICATORS & HORN
CHECK OPERATION OF FRONT I REAR WIPER I WASHER SYSTEMS
CHECK CONDITION OF STEERING. SUSPENSION BOOTS. AXLES . SEALS
REPLACE IN CABIN AIR FILTER (POLLEN FILTER)
PERFORM ANTI-CORROSION CHECK
LUBRICATE TOP EDGE DOOR SEALS
CHECK BATTERY CONDITION: FILL IF APPLICABLE. CLEAN TERMINALS
CHECK CONDITION OF ALL DRIVE BELTS
CHECK & TOP UP BRAKE, PAS AND WINDSHIELD WASHER FLUID
CHECK COOLANT LEVEL & COOLANT PROTECTION
REMOVE ROAD WHEELS & INSPECT BRAKE SYSTEM
CHECK TIRE CONDITION . PRESSURES AND TREAD DEPTH
LUBE WHEEL CENTERS &INSTALL ROTATE WHEELS/TIRES IF APP.
CHECK FOR ANY LEAKS. CHECK BRAKE. FUEL & PAS HOSES UNIONS
ROAD TEST VEHICLE
PERFORMED SCHEDULED SERVICE
NEXT SERVICE: 1 YEAR 15K
Any ideas as to what they screwed up so I can tell them to fix it when I drop of the car?
If they really road tested they should have spotted this - take a video with your phone to show the advisor ... Get them to Check torque of wheel bolts - but from your description could be sway bar bushings ... That's probably not down to them though ...
