1 - 12 of 12 Posts
Well just as subject says, I hear something loose up front when I hit bumps. Sounds like something on the suspension is loose? Dealer said "they tightened some bushings or something" but obviously that did not fix the problem. Anyone else have this problem? Thanks in advance.
Welcome to the club and thanks for joining (the clunk club not RR.net). You can't really tighten bushings, they're either shot or their ok, and your dealer needs to look elsewhere, like the ball joints.
Mine's in right now hopefully just getting some new sway bar bushings. I'd hate to think my BJ's (ha ha) were shot at 39k.
2010-2012 Range Rover Sport
I went in for the same problem.. and their response after checking was that they 'couldn't recreate the sound.' Since I'm not too savy mechanically w/ autos.. I didn't know what to tell them to check.
So Ukraine.. what do I tell them to check.., I'm sick of their run around. I have warranty till July.. but would like to handle this now rather than wait.
Thanks my European Brother,
Bojan
Bojan
hey no problem...You might have to take it for a ride with them and reproduce the sound, unfortunately. Tell them to check the front sway bar bushings which are known to wear quickly. They should be aware of this as it is fairly common in the RRS. It could also be the ball joints, though that is less likely unless you have higher mileage. From everything I've read (mostly thanks to this forum), it is one of those two things.
Also bring in a copy of the TSB like I did, which states "Knocking noise over uneven pavement while driving straight ahead". The title is literally what I was experiencing. Sometimes you gotta treat them like 10 year olds and wonder why you know more than the service advisors there.
I just got mine back about an hour ago after they replaced the front sway bar bushings and it drives like new. Good luck.
Where did you find the TSB which states "Knocking noise over uneven pavement while driving straight ahead"? Looks like I will have to take that in with me. Thanks.
· SUPER MODERATOR
2013 RS, 2017 FFRR
Ukraine Range said:
Here you go guys, go to Umbertob's post from 11/20 at 4:48 PM (4th on the page), and open the second attachment:
viewtopic.php?f=5&t=27763&p=275359&hilit=tsb#p275359
Will bet you guys $100 its your swaybar bushings. Thanks Umbertob!!!
Let's hope so...give us feedback in 1 week's time if the sound comes back.
it IS the Swaybar. I had the same issue thought it was the Tie Rods but it wasnt. I had the dealership replace the swaybar (under warrenty) and no more knocking/clunking sound when i hit bumps. it is the swaybar and once you replace that no more problem!
Had exactly the same problem. Sounded terrible everytime I passed over the smallest of bumps. Found it to be no more than a loose mud shield behind the brake disc. Held in place by 3 mud shield retaining bolts which I removed and refitted with larger washers to secure the shield in place. Easy fix for the price of 3 washers
If you still have the car is it still not making noise? Am selling my 4 months old car because it seems they can't fix this. Head over to L494, and L405 threads search for suspension clunk. Some of us with 2014s are going crazy with this issue. Shocked to see this was same thing 4yrs ago! If I had found this site before I bought maybe I would not have bought it. Love and mostly hate relationship with the car thus far.
1 - 12 of 12 Posts
