2009 RRS SC 4.2L L320
Hi All - I'm working on my L320 (4.2L Supercharged) and found an oil line running from the Oil Filter Housing to the Oil Cooler leaking .
Anyone happen to know the part # for this bad boy so I can order and replace it? I've done a bunch of searches online (including roverparts.com) but can't seem to find the right line (or maybe their images are not correct).
Anyway - Thanks Much!
Product Automotive tire Wood Gas Cable
Discussion Starter · #2 · (Edited)
So I found a part # for the actual oil cooler lines (PCH501122) but they do not come with the connectors show in the image - Anyone know the part #'s for these connectors or is this a case where I can simply double clamp the line if needed?
I'm building a "crash kit" of parts to have on hand while out playing in the desert.
Thanks Again!
  • Like
Reactions: gemery007
You started out talking about the oil cooler lines and your second post is about a coolant line. These are not the same animal.
The oil cooler lines come with all connectors on the lines.
PBP500105 PBP500105 Oil cooler line - Devon4x4.com
PBP500094 PBP500094 Oil Cooler line - Paddockspares.com
You can search parts diagrams here, use chrome to translate the pages if needed. Lrcat
Apologies for the confusion and thanks for the correction and part #'s!
Let this be a lesson to others to not drink and look for parts at the same time.
