My rear windows would not operate and traced problem to no power to the fuse on fuse box. From wiring diagram looks like a relay is bad. Wiring diagram shows relay is on the fuse panel behind the glove box. I see about 7 relays there but these are not for the windows. I called dealer and tech said the are "behind the fuse box" I don't see anything and to remove the fuse box to look behind would be a huge job with all the wiring connections. I did check the under hood fuse box, more relays there but not for the windows. Anyone no where this relay is located?
Regards
Regards
