2015 Range Rover L405 Supercharged & 2006-2009 Range Rover MkIII / L322
I need to replace the pch501310g Hose. I can't find it's location. Changing due too erratic thermostat readings.
It's down on the drivers side of the radiator, just forward of the oil and transmission coolers. It is actually attached to the radiator housing just above the lower radiator hose. You have to remove the lower plastic "skid plate" to get at it, may have to remove the oil filter if you have big hands.
