1 - 14 of 14 Posts
2010-2012 Range Rover Sport
I would look for any aftermarket switch near the steering wheel or radio controls, I’m definitely betting it’s a laser jammer instead of led light because that’s pretty much exactly what they look like.
2006 Range Rover Sport 2016 Mercedes S550 4MATIC
I don't think they are LED lights: if they were, the light-emitting silicon diodes should be visible. Here they are not.
That’s a Blinder M## laser jammer. Had it on my car back in 2011. Used to work flawlessly. Jammed a lot of laser guns. Now it is obsolete. If you want to upgrade the laser jammer I recommend ALpriorty.
2013-2015 Range Rover Sport
k40 vintage model, had them on my car
The escort is a good unit for radar defense.
I am using the 9500ci for radar protection.
Currently the only laser jammer that can jam the dragon eye is the ALPriorty.
That's interesting. I will check it out.
This is the escort 9500ci set up. Laser jammer and Radar/laser module. (9500ci is obsoleted and replaced by the new escort max ci 360)
Even if they aren't useable, the wirings are probably still good. It'd save you some work if you decide to install new ones.
you can’t reused the wiring, different laser jammer company used different wiring. it will be easy to Install the new wiring by following the old wiring.
I have one of the Escorts, barely use it recently though. I really like its iPhone app. You can see radar and laser signals detected by other Escort users. This extends your detectable range by a huge margin. Waze has similar features. But those are manual inputs by users. So it isn't as robust. When you take a long trip, the combination of the Escort app and Waze is awesome.
1 - 14 of 14 Posts
