Hello,
I installed H7 6000K pure white on Hi beam, H7 3000K yellow on Fog beam HID kits on my '07 RRSC.
Some reason I got problem on Hi beam of right side bulb. Is there any way to correct, to tune bulb Hi beam using screwdriver?
I tried using screwdriver, there was two location under hood to change beam movement up/down/right/left direction.
But when I fix Low beam level then Hi beam level moved up, if I fix Hi beam back to normal level Low beam accordingly moved down.
How can I solve this problem?
Balgaa
I think your problem is that the reflectors for Hi Beam are not designed for HID bulbs their spread of light is totally different to halogen bulbs , many people fit HID's only to find them utterly useless due to erratic light spread . :crybaby2:
Its also possible that the light bulb did not sit properly on the holder throwing one high beam off. The adjustment is design to adjust both high and low together.
