At times my left hand indicator flashes twice the speed and when it does the external indicator lights do not light up, but when it flashes at normal speed all three external indicator lights are lighting up. Do the 07 Range Rover Sports have relays which could be the problem, if so where is the relay located.
My guess is one of the lamps is going bad and causing the intermittent problem not the relay. Problem is figuring out which one it is. If two lamps are the same get a new one and try each. If that doesn't work then most likely the third lamp.
Best if luck.
"all three external indicator lights are lighting up". Is this normal?
'06 RRS LUX
'06 pilot EXL
'91 4runner
