Hi Marty.....
Well I'm halfway through my interior lighting renewal and so far I've replaced the the incandescent bulbs in the HEVAC system, Instrument Binnacle and Fascia Switchpack.
LEDs have replaced the bulbs in the Centre Console (power window/sunroof) Switchpack, dome lights and map lights and rear power window switches. I'm installing footwell and puddle lights in the car and those will also be LEDs.
My question now is this- I'd like to replace the incandescent bulbs in the HEVAC LCD and Message Centre LCD with LEDs to prevent the heat from these bulbs from damaging the LCDs. My HEVAC LCD had already faded due to this and I'm seeing the beginnings of similar damage to the Message Centre LCD.
I managed to fix the HEVAC LCD but it was a right b*&&#r of a job and I don't want to have to do it again- ever!!
What sort of LEDs would you suggest/ used in your own conversion.
I've tried once with these:-
... and no joy- the light doesn't diffuse properly due I think not only to the highly directional beam coming from these but also the fact that the light source is a LOT closer to the screen compared to the original 286 incandescent bulb! Plus the green from the LEDs is unpleasantly unnatural and put me on edge all the while I was looking at it.
I'm thinking of trying again with these:-
Warm white will give a more natural hue and SMDs should place the light source further away from the screen.... but I don't want to go ripping the dash apart just to find out- if you've got a working LED solution already it'd be great if you could share it with me!
