At my local garage and I have a massive leak from above the oil filter - just drained the rig and got all of a litre out :shock:
Would anyone with rave access be kind enough to upload a diagram from Rave for this location?
I tried searching the forum on my iPhone, but could not find it.
Thanks for any and all help.
Hi Karman,
I had the same problem on my 1998, I accessed it by lifting the front right wheel up, take the wheel out, and remove the wheel inner fender plastic cover, and u will clearly see the pressure relief valve, usually the o-ring is the reason. when it goes bad it leaks a lot. hope this will help.
ZEE
Hi
For the pressure relief valve o-ring look at:
viewtopic.php?f=3&t=39814
It could also be the oil pressure sensor leaking they are notorius for it and very cheap to replace. You might as well do both at the same time.
Regards
Jos
