Hi All,
Just looking for some confirmation, please.
All searching says that the P38 with 4 wheel traction control has a 4 pin front diff.
Is this correct?
Ashcroft think 2 pin.
Cheers.
I had always assumed that cars built from 1999 onward, i.e. those with 4 wheel traction control, had 4 pin diffs. However I remember reading about someone who took a front diff apart on a later car and found it was 2 pin, so there is a bit of confusion about exactly which models are 4 pin.
Thanks all.
Consensus seems to be 2 pin at the front.
Cheers.
R
Guest
little translation problem overhere...
if you mean by "consensus seems to be 2pin at the front" that all P38 have a two pin in the front.... then no, not all...but yes, there are post my99 (4wheel TC) P38 which do have 2 pin
I've got 2001, which is 'supposed' to have 4 pin fitted...
When I removed it (from the PITA the hub was to get apart, I doubt it had ever been done before) it was 2 pin. Don't know if it's because mine was in the last year of production that it was a case of 'chuck in whatever is left on the shelf' or whether the 4pin front diff on the later models is a myth..
Let us know what you find when you get your one out!
Marty
