on the spot welded panel in the middle and both corners. I have attached the pictures to make it more interesting as I know this subject has been flogged to death and gets boring. Any help would be appreciated.
I'm only able to load one photo for some reason.
I've seen the same on mine.it'd be appreciated if the info pertaining to this leak could be shared here on the thread. Thanks all, anxious to hear!
Hi all I am in the process of changing the tail gate seal and I notice in the spongy bit that is the seal there are 2 stiffer areas are these supposed to be located in a particular location i.e. Corners/next to catches.
I think the leak was from the top tail gate hinge bolts I have sprayed that area with ignition plasti coat sealer and it's fixed it. That was a lot easier than removing the whole lot and sealing it. I'll let you know how it goes.
