Good evening guys!
Im looking for the rave manual for 2006 4.4L v8 petrol or any other manuals or documents so when it comes time to work on her, there i have the resourses.
i have already checked out http://www.d-lander.com/manuals/ however, the year and engine isnt covered in the list so i was wondering if anyone else had these manuals.
Thanks! :]
eManualOnline.com has the PDF for the 4.4L and the 4.2L SC engines and drive trains for $20. I bought it, but it was the same as one that I found online for free, which I can no longer find. The RAVE manual for the 2002-2005 remains valid for the body and interior components.
The only one that exists (at least that I've found is one that is sort of an insert into the 07 to 10 Workshop Manual. It has all the engine stuff and whatever other changes were made for the 06 year but it's kind of funky to use as it references you off to other sections that you have to go to the later manuals to use.
This set contains 5 different chapters, 01 General Info, 02 Chassis, 03 Powertrain, 04 electrical, and 05 Body and Paint. Under engine for example, there is
Part 303 Engine, Part 307 Automatic Transmission, Part 308 Transfer Case, Part 309 Exhaust System, and Part 310 Fuel System. The engine section contains only the 4.4L info (because the 07 to 10 has the 4.2L and 3.8L TDV8 info)
There seems to be complete manuals for the 02 to 05, then this weird 06 addendum version, and then an 07 to 10 manual.
