It'll be a bit more work than that. A P38 clock spring only feeds for SRS, radio and cruise. L322 then adds feeds for the heated steering and telephone. The steering wheel would most likely. However you would need the harness, clock spring and airbag. Most importantly you would need to ensure that the air bag will trigger with the same communications signal as provided by the P38 SRS ECU.
