Since I've bought the truck the past year the steering makes an squeaky noise while the steering wheel is at the end of the steering range, not matters if the steering was turned to the right or left.
What can be?
Loose auxiliary belt probably that is slipping on the power steering pump at full turn
Indeed, it was the belt, thanks. It had 2 Dayco made in italy belts, the were fine, doesnt looks worn, but maybe they are old and got a little loose. Now the truck use Continental Contitech made in germany, .
banda-accesorios-alternador-6pk-2080-contitech-D_NQ_NP_719028-MLM27246908764_042018-F.jpg
Could be the power steering fluid is low.
