Hello I have a 2004 L322
generally runs very well
When it has been idle it doesn’t want to shift down gear when accelerating at about 50mph - but this only seems to happen once then it clears itself -
Grateful for advice
Do you know the last time the transmission oil got changed along w filter? Chances are she's due at that age.
While the gearbox sump is apart, you may want to replace the shift solenoids and any internal seals.
I just did this with my 07 (6HP26) to fix a trans fault code. The cost of the solenoids and internal seals is about the same as the oil and filter kit. I changed the oil and filter 10k miles previously and had I known about the solenoids, would have done them at that time.
