I have a problem with the central locking on my 2003 (L322)RR Vogue. It all works as it should apart from the driver’s door not unlockingwith key fob. When the key is pressed I can hear a “clunk” noise in the door.The driver's door can be opened by inserting the key into the lock. If usingthe dashboard locking button, all doors lock and unlock apart from the driver'sdoor. I think I can deal with dismantling the door myself but need to know inadvance which replacement parts to buy. Your help and advice would be muchappreciated please.
I had almost the same issue as yours with my 2004 HSE. The difference being there was no clunk from the drivers door when the remote was pressed. I tried using a universal door actuator, a fix for the P38, but wasn't able to get it to work. I ended up getting a new driver's door latch assembly. Not tough to R&R, but make sure the drivers door window is rolled all the way up before disconnecting your battery.
Another tip, when I took my interior door trim off, some of the clip holders had come detached from the door trim. I was able to use JB Weld to re-attach them with success.
