Hi, mk3 2010 vogue model.
One day, I started to hear knocking sound on the sound. The service center says they don't know what you.
You know what's causing this noise?
I recorded near spare tire in the trunk
knocking sound
you can check knocking sound after 21sec
sorry I did't attached file. so I up load again
[QUOTE = "buba, 게시물 : 2298369, 회원 : 190770"]
엔진?
[/ 인용문]
It is a diesel engine
You know what's causing this noise? Visit AutoGuysLand to review why car wont go into gear manual if you concern.
knocking sound
you can try to check hub/control arm if it is loose so you should replace and get fix.
it sounds very similar to FBH (Fuel Burning Heather) pump located in the left rear, try turning heating off / center knob on the dash board turn all the way to the left, this will turn FBH off.
[QUOTE = "Ricardowelch, 게시물 : 2298489, 회원 : 443619"]
허브 / 컨트롤 암이 느슨하면 점검하여 교체하고 수리해야합니다.
[/인용문]
buba. Thanks for your advice.I will check soon.
tanks again
I didn't think that and I try it. Thanks a lot.
