1 - 11 of 11 Posts
Agreed, not a Land Rover issue. Remember, even Chevy has this system.
I work in Chicago and looked into disabling the door lock system.
https://www.youtube.com/watch?v=qskP9czE7uc
Came across that, it worked on my L405, haven't tried my L494 but considering that the video is for a 494 I'd assume so.
2016-2018 Range Rover Sport
Kryptonite is the answer. Encase the fobs as well as the entire beast in kryptonite and you should be ok.
2013-2015 Range Rover Sport
This article shows you how hackers can still your Range Rover Sport in under a minute. I am wondering if I should put my key fob in a metal can when I am home. I had no idea it can be so easy. I hope Land Rover beefs up their security. Here is the article: https://www.dailymail.co.uk/news/ar...r-Sport-worth-60-000-Harborne-Birmingham.html
No need to buy gadgets to do this, just wrap your key fobs(spare one also) in aluminium foil and there is no way the signal gets through. Try it with your mobile/cell and you'll see.
The method deactivating keyless entry posted by Keralis does work though, don't know if on every model, but a shame to lose the feature..
2019-2021 Range Rover Sport
2016 RR Sport SC Dynamic
These posts on here is why I always wrap my fob in aluminum foil whenever it is parked outside, such as when visiting family.
And I'm the guy that had to spend a few hundred bucks because my only key fob was in my briefcase, which I placed in my trunk, and my RR couldn't sense it was inside - I shut the tailgate and was locked out... #notsmarterthanthethieves
as long as you have a 17 or newer, your phone can help in such case (not by calling someone but by using the app)
1 - 11 of 11 Posts
