I have been reading that the IIDTool BT is capable of programming key fobs but I do not see it listed as a feature on the Gap Diagnostics website. Can you confirm this is possible for a 2016 RRS L494 with an applicable key fob?
I went through the same with my ‘12 RRS with a key I bought off amazon for $70. Between the key and not having to buying and installing lift rods, it pays for itself with just that alone.For anyone else trying this, I just added a key on my 2010 RR (I wanted to update to the newer smaller fob). When programming every time I tried to walk through the process to add the key the iidtool software said that the process failed, then randomly after the third failure I looked at how many keys were in the system and it said I had one more than I started with. So I tried out the new key that it said failed and it worked fine, so even if iidtool says adding a key failed, give it a try and maybe it works ok.
I’ve gone ahead and ordered gap iid tool and a programmable key.Hello Guys,
Can I program new key for my Range Rover 2007 Sport SuperCharged with this GAP tool?
Where did u buy the programable key?I’ve gone ahead and ordered gap iid tool and a programmable key.
it was super simple to get up and running with it and breeze to program the key.
Gap iid is an excellent tool.
Hello friend, I've got it from Lucky LLC but I wouldn't recommend you to use their keys.Where did u buy the programable key?
