The rod has fallen off.
I’m hoping you have access to the car, with the window down, shine a torch down and you should see the offending rod that’s disconnected.
only a matter of removing the door panel and carefully peel back the vapour barrier, if the plastic retainer is broken, they can be purchased separately.
if your locked out you need to have a read up on removing the rear quarter light to gain access.
I had the same, the rod came off, so took the door card off and refitted.
Bit of a panic knowing how the central locking was.
But easy
Sent from my GT-N8010 using Tapatalk
