Hi all..
Proud owner of Disco 3 since 12 years... Just bought a 2003 L322.., but the first thing i noticed is that the working range of key fob is very low.. it just works only about 2 meters around the vehicle.. changed the batteries in the key but no affect.. any advice pl..
I can lock and unlock my 2004 from inside my house with the car 40' away. Looking at rave, the rear window heater element/antenna attaches to the RF receiver/antenna amplifier. Is it possible that your rear window was replaced and the antenna wasn't hooked up? The other alternative is the key fob electronics are bad, if that's the case you can buy a new key fob with electronics for around $20 and put the new electronics in your old key fob. You'll have to re-sync your remote before it'll work.
Thanks for the reply Freeman.. i checked the contacts at the rear window.. it seems connected well and in place..how to check if its working, can it be replaced..?
Thanks MrE..
Im here in Pakistan.. probably its a UK spec.
Its 2003 vogue 4.4 petrol..bmw engine..
Can u pl advice how to replace the RF module.. is it some DiY easy job..
