1 - 10 of 10 Posts
Hi Guys. Anyone tested this in case of head gasket problems and if so, is it any good ? What harm to the engine, if any, this thing may do??
https://www.kseal.com
It won't harm the engine but it will clog the radiator and heater matrix up nicely so whatever problem you are trying to fix may be fixed but you'll add others. If it needs a head gasket, give it one.
RIP Our Friend
Yea, if you have any desires to keep your rig, do a proper job.
..certainly im after keeping my rover as long as im around..i thought its good to keep this think in a trunk, just in case...by the way, is there any step by step guide for head gaskets replacement (4.6 GEMS, 1997), including proper order of tightening screws and corresponding torque ?
RAVE, Overhaul Manuals, Engines.
JACK'S GRANDAD
You joined eight years ago, and still haven't figured out the search function?
Everything, including the K Seal junk, has been covered lots of times.
Martin
Discussion Starter · #7 ·
..well..obviously, i did not..but its never too late to learn new things..
https://www.youtube.com/watch?v=Zwdg1XCsI_w
This is the one I will go by some day.
I don't hate Kseal I put a half bottle in the RR after changing heater core and radiator. It is frowned upon because if anything is old
and corroded inside it will probably clog it worse.
RIP Our Friend
Ecco, in the 7 years you have been here have you not read the guidelines? First item is to search. The guidelines also note to have your Rover's info in your signature.
You have tons of info at your finger tips. Don't you think it's time to at least try to find the answers to your questions before making repeat posts?
I not long ago did a head job on a 4.0 gems, upon start up I found the complete radiator core was blocked solid with a similar item, would I use !. NO
1 - 10 of 10 Posts
