What do I need to worry about ...?
The car is Deep Black / Cream and in MINT original condition, with 65kmiles.
There are No problems and it runs smooth, but i want to have it serviced prior to issues..
any suggestions on what I can do as part of recommended services..? or should I just drive it 'til it needs something..?
thanks and let me know
-IPXIH
If you don't have the full service history, I would change out all the fluids, so you have a base line to start from. Try and do it yourself, because it is easy and good knowledge to have.
Other than that, drive it and have fun.
I am new to the MKIII - but from the local rover tech i did these things with mine - of course myself not at the dealer:
1 - Transfer Case fluid change
2 - Tranny fluid change - look for metal parts in the fluid - if there are some then be ready for a rebuild or replacement
3 - Fluid change on the diffs
I also replaced my expansion tank, radiator, hoses on the radiator (bmw converter/connector) water pump thermostat and expansion tank cap. But i may be more paranoid than most. All the above was not that much money since i did most of it myself - about $1k total.
Hope to be ready for another 60K miles.
JH
Thanks much for the info.
i am mechanically inclined and have plenty of tools. Should I get all the oils from Rover Dlr only or local parts store..? I assume it will use BMW X series fluids..
