Hi all, another Newbie who loves his RR but has little knowledge on it abilities and 'attributes' (i.e. all the noises from under the bonnet that aren't the V8!).
Looking for reassurances more than advice, but would welcome both.
The brake pump does go on an awful lot - I have had the Accumalator replaced and it went from going on every second pressing of the pedal to every 3rd/4th press - the pump stays on for about 5 seconds. Is this a normal operating trait? I have done some looking on this forum and it mentions 4 presses to 10/12 before the pump should go on. Just concerned as I've also read that if the pump fails (where the system loses pressure), the brakes fails and when I have my wife driving :doh: and 2 kiddies in it, just want to make sure I have no underlying issue.
The back light on the HAVEC display is also intermittent - also looked this (great) forum but it only talked about bulb replacement. Some of the display is there, then it all disappears, then only to return 5 minutes later.
Has anyone fitted parking sensors - looking at some on trademe (New Zealanders Ebay!) and wanted to see if anyone has experience of fitting these aftermarket kits.
Thanks for now - when something seriously goes wrong, I just hope the warranty covers it - just hope its not the suspension as that seems excluded for some reason
ray:
