Pull the fuse on the navi unit and see if you still have a batt drainRoverHomie said:
Pull the fuse on the navi unit and see if you still have a batt drainRoverHomie said:Hey guys just need some input on this problem.
I took my 03 HSE in for a battery drain issue (which has been thoroughly documented in these forums)
The dealership is telling me to solve the issue I need a new Navigation Unit priced at 2400 installed.
I'm surprised the entire unit needs to be replaced to solve the problem, any thoughts?
Well now you know where it's draining from, you can either go into rave and start testing all the probable locations or pay someone to do it. It could be as simple as a wire, could be some internal damage inside the nav/audio... I'd start by checking all the connections.RoverHomie said:When the fuse is pulled (I forget the specific number) the battery drain stops. Besides paying full price for a new unit I have 2 options, Buy one off ebay or wire a kill switch to the fuse and hit it once the vehicle is off.
Thats certainly something way beyond my skill set with electronics.gw2doc said:some people find following wire schematics confusing, others dont, it definetly doesnt need to be a dealer to do it if you dont want to do it yourself.
what about a local LR mechanic?RoverHomie said:Thats certainly something way beyond my skill set with electronics.gw2doc said:some people find following wire schematics confusing, others dont, it definetly doesnt need to be a dealer to do it if you dont want to do it yourself.
