'93 County LWB: The red dash "brake" light came on this morning on the way to work, pulled into the parking lot and stopped normally, but I shut it off and turned the key back on, and the telltale ABS pump running didn't happen.
I'll check the fuse(s), but could this well be the demise of my ABS pump? How far can I drive it off accumulator pressure?
Discussion Starter #2
Update: At lunch I went out to the truck, cringed and gritted my teeth, then turned on the key.....and the ABS pump cycled for a LONG time until the accumulator got up to pressure.
Is this typical symptoms of a failing ABS pump (intermittent failing), or do I likely have just a loose power connection?
