After reading many forum posts wrt rebuilds and breakdowns, my favorite so far was from RoverMasterTech's writeup as follows: Main/Crank Bearing replacement write up - Land Rover Forums - Land Rover Enthusiast Forum
I believe that for me and my car, his insight and approach captures how I would like to approach my problem as follows. If anybody can please recommend and make pertinent suggestions Im all ears. Myself and the car are conditionally ready and willing to face the challenges that may come.
1995 RRC LWB:
~266,000 miles
Routine maintenance only after all this time...
Car is/was running "strong", no smoke, good gas mileage and handles fine, other than the tap, tap, tap and now the knock…
My local and knowledgeable LandRover "expert” mechanic team said I have rod knock in the bottom end. I hadn't really noticed because of the top end tap. Once he called it to my attention I do hear it.. (he said the exhaust manifold was leaking but I don't really notice it and that may be masking the knock somewhat.) They said catastrophe was eminent and the lead tech would NOT drive it further…that was after he put in the new Power steering pump and damper and test drove it for a spin.
He also said that the FRONT COVER was obsolete and that IF the oil pump had damaged the housing ( he was pretty sure it would be trashed) , then fixing anything was not an option, because even a block swap needed the old cover and those were impossible to find.
SO, I intend to pull the cover and inspect the PUMP and housing and keep a tight hold of the cover until I know it is not re-usable. ( Anyone hear of remanufacturing those? Why hasn't the part been resurrected ?)
IF cover is GOOD, then I will need gears to replace the pump , the timing chain kit, pickup tube o-ring, gaskets, etc … water pump is new but "TWO LONG bolts on driver side lower" threads stripped as I was torquing them in the cover for sure.
Also, before doing the pump/timing chain job, iff COVER is good I will inspect lower bearings and replace ( mains and pushrod) if the Crankshaft/Journals are not out of spec.
If crank appears trashed or bearings walked, then Ill pull the engine and have it rebuilt somewhere near Austin, TX or send it away or locate a rebuilt… ANY SUGGESTIONS on other local experts, options?
I Will need plastigage to inspect the crankshaft? (will that work on old beings or Do you need new to check??)
How does that sound?
Thanks in advance for your help.
Other plan is put it back together, and sell it as is to someone who wants the challenge. Minimal rust and never wrecked. Typical issues but nothing major.
P.S. If someone had said at 160K miles to rebuild the pump I would have for sure, but I never considered it and Bill never suggested it. I was happy to have an incredibly reliable automobile that never left me stranded and always started. I truly wonder about the horror stories I read on this site wrt money pit rovers. Mine never was and 266K miles later I know Ive spend more on gas than what I paid for it easily.
1995 RRC LWB:
~266,000 miles
