99 HSE Bosch 165K. Can you remove the front main crankshaft bearing without removing the timing cover? Someone said in order to remove side bolts with dowty washers you have to remove the cover. Anyone know for sure?
FOUNDING MEMBER
if you have a bad bearing, you want to inspect/replace the oil pump anyway....
after doing headgaskets, cam, cover, sump in vehicle-it's easier to pull the engine...trust me.
once it's out, do it all.
