Is it possible to put 19" wheels on a sport SCV8 Dynamic?
Does anyone know if this is possible? The lowest available size on the configurator is 20" wheels and I think that's due to the 20" brakes. Has anyone actually tried going lower? Is there enough clearance? I'm looking for a set of off-road wheels and tires and would like to go as small as possible.
Re: Is it possible to put 19" wheels on a sport SCV8 Dynamic?
I never tried it but would caution against it. I mounted 20" winter rims and the tolerances were so tight I had issues with the balancing weights. In the end it got sorted and 20" fit but just barely.
If you do try it you'll need to make sure the internal diameter of the rim clears the brake rotors and the one that surprised me, the width doesn't interfere with the upper control arm.
