I have a 04 with 86k on it and sometimes the trans will automatically downshift by itself and sit in that gear until it gets to about 3500-4500 rpm. I had the car checked and they said nothing is wrong with the trans. What could this be? it also doesn't like to downshift when i want it to or while going up a canyon road.
Also does your suspension move or reset after driving on the freeway?
Thank You in Advance
Nick
Unless you've had your radiator replaced at some point, the transmission issue is most likely to be caused by your engine radiator having become blocked by sediment/corrosion at the bottom. This doesn't effect the engine running temperature, which continues to display 'normal' on the gauge, it just starves the transmission fluid cooler of cooling water.
viewtopic.php?f=2&t=36021#p279263
viewtopic.php?f=2&t=36128#p280245
Phil
