1989 Range Rover Classic
I know door locks have been discussed at length on this forum, but I couldn't find something with this specific problem. The power door locks on mine used to work fine, but lately (couple weeks) I have noticed that the passenger side has become intermittent. About 70% of the time, all four locks behave as normal, and 30% of the time, only the two driver's side door locks will respond. Is this a sign that the control module is going out?
Could be. I’ve gone thru 3 modules due to a leak that keeps dripping on the module and shorting the pcb. It could also be a bad actuator in front. What year is your rig?
'89. Where is the module located that it gets dripped on?
On my ‘95 RRC, it’s under the front dash, passenger side. Check RAVE/ETM for 89.
On my 1990 & 1992 the Door Control module is (USA) drivers side, as if your sitting in the drivers seat its above your left knee - behind the panel
