2010-2012 Range Rover Sport
Please be gently with me, Forum virgin :)
I've just purchased a 2010 Range Rover Sport 2010 and decided to change the interior bulbs to white led from the standard bulb. All lights were working prior to bulb change.
I've now changed all bulbs but the two front door lights have stopped working, all other interior lights are working fine. I've replaced bulbs with known working bulbs and still both not working.
Any Ideas please?
Many Thanks
Darryl
2015 Range Rover
We're these the front door led on the bottom of the door. Puddle lights I think they call them? If so if you put bulb in backwards it faults the system and when you reverse polarity it still doesn't work right away. You need to close the door lock it and wait a few mins then it resets and will work. For some reason this only occurs on the front two doors.
Hi, thank you for the advise, unfortunately they re still not working. I've taken the puddle units out and fitted them into the boot of the car so I know the unit and bulbs are fine but they are still not working.
Is there any way I can reset the system? i've checked the on boad computer and it's not showing any errors.
