Trying to activate the menu button on the instrument panel , the manual says just press for a 3-5 secs but not happening.The only thing that may be stopping it working could be that a message is trying to tell me I have a trans safe failure would this interfere with normal operations.
Discussion Starter #2
Message board clear again but still no Instrument menu.
Really don't have a clue, so I'll throw out two 100% random thoughts...
1. Turn everything off and remove the key, wait 2 minutes, disconnect the negative battery cable, wait, then reconnect to shake a squirrel from the tree. (Then start the engine and briefly turn the steering wheel full-left and full-right to reset the steering sensor.)
2. Check battery voltage, 12.5 volts or more is healthy.
