Hi all,
I need to get at the back of my clocks to replace a bulb. The manual says unclip cover, the handbook says unclip cover.... which way do i pull or push it? where abouts are the clips holding it on? I dont want to break anything.
cheers !!!!
Which cover exactly?
Distmantling interior trim... One if lifes great tests.
Hi,
its the one which covers the top/back of the instrument cluster, enables access to the rear of the clocks to change bulbs.
cheers
If it's the hard dash Rangie (I'm guessing your 1988 in the signature), then there are little lugs at the bottom of the binnacle holding it in. If you're sitting in the drivers seat, grasp each end of the binnacle cover and lift and tilt it slightly towards you. It should give enough for the bottom to come over the metal lugs. Once it's done that, it only slots into front face of the binnacle and should come free.
