My instrument cluster is little dark when the lights are on, maybe its dust or burned vials, although the information LEDS works fine. Can I install the instrument cluster of a 2008 SC in my 2004 HSE?
I don't think you can go up from a 2002-2005 IPC to an 06 to 09 IPC under any conditions, the networks in the truck are completly different. Also the IPC is vin locked to the other computers in the truck, and actually contains one of the main configuration files for the truck, so without being able to reconfigure it (If its possible with the LR software) swapping clusters within their same family (BMW or Jaguar) will disable your truck.
I presume its also not possible to change a 2008 Vogue cluster to the newer TFT one?
